thanks for the info, both times. i will read the post and look at the site. thanks again.This is where I bought the kit that I used in my thread in the tranny section ......... If this is on your 93 you may have to replace the external connector with a pigtail they sell. The oe connector on 91-93 is different from newer somewhat improved ones.
:???::WTF: I don't know why it does that lately. It has happened several times. I didn't submit twice:???::skep:thanks for the info, both times. i will read the post and look at the site. thanks again.
i will def do that.I would go with Leroy's suggestion of goobering the inside of the internal connector up with RTV or other sealant.
i will def do that.
Barry made it look so easy!
The worst part is the tranny fluid dripping on you the whole time
when i have the pan off, gonna put in a drain.
Aftermarket drain plug kits are mostly junk from what I saw.Much better to just weld a pipe coupling to the pan and use a standard pipe plug.
