Hunter
Man, I haven't been on here in awhile. I did a quick search with no luck. Anyone out there have an opinion on a really strong front driveaxle replacement? I keep snapping mine in high RPM/torque situations. I did it again yesterday trying to pull my dad's dead backhoe back to the shop.
Now, I fully know this is happening because of my lift kit. At the time I went with what I felt was the best choice for me. It's from Cognito Motorsports. It's the non-T-bar drop 4-6 inch kit. Originally set at 4 inches, I never had any problems. They even say at 4 inches, all geometry is the same based on their desiing (it drops the front diff 4 inches apparently). They too say at 6 inches the drive angles will be slightly off, but should work fine. It does use spacers regardless for the front axles.
Recently, I used a new alignment guy when I put the new tires on it, and he simply couldn't get the camber right. I called Cognito and they recommended their aftermarket (longer) upper A-arms to help with that. It did the trick, but made it a 6 inch lift, so I added the appropriate rear blocks. Now I've broken 3 axles in as many years. Granted, the NAPA Remans I'm putting in there are probably part of the issue. I think I want to try what will be an interim stronger axle at least. Any suggestions? I'll reach out to Cognito again as well.
Eventually, I intend to upgrade the whole front end. Probably keep it IFS, but do a locker, stronger cross shaft and tougher driveaxles. I read an article about all of it, but can't find it right now. But they used these (WARNING: this is insane):
I digress. Short version :What's the best, toughest aftermarket front driveaxle for my truck? Or do you know of a longer axle for lifted trucks?
Thanks!
Ultimate IFS SST CV Axle Set for GM 2500/3500 ('88-'11) & Hummer H2 ('02-'09) - 6 Bolt Flange
RCV Ultimate IFS CV Axles for Independent Front Suspension are designed to overcome the limitations of your GM 2500 or 3500 IFS axle shafts. Ultimate IFS CV Axles provide increased range of articulation for vehicles modified with a lift kit or long-travel suspension, and provide strength that...
www.rcvperformance.com
Thanks!
