Bearing & Piston clearances tightened up
Twisted Steel Performance
Pauline, SC
Bearing or Piston clearances not what you want, I can fix that..
Bearing buildup & DFL on the surface.
I can build up bearings on the back side to tighten up clearances, and also build up piston skits as needed. The buildup can be anywhere from .0003"-.003", this is permanently bonded to the base metal after curing.
@Hink
