sshewins
Jesus Freak
Makes me wonder if this would "help" other turbos as well? Or is this really only beneficial to non-wastegated turbos.
Definately interested and watching this oneI will be hitting the dyno monday if anyone cares to know. Will keep you guys posted
Looking for any gains myself, but FWIW the down on bottom spool really is nowhere as bad as some would lead you to believe with the ATT, this IMO is a enhancement to what I would call an already success.Can't wait to see the results, really interested to see how this affected the low end of the curve
I can't wait to see a video of it in action.
I'm running the ATT right now
I'm looking forward to seeing your results.
Are you running the tune designed for the HX clone on the ATT? Fueling properties of the tune designed for the HX clone? Maybe your tune should be optimized for the ATT if it isn't then the test is not relevant without a tune optimized for the turbo like your tune is for your HX clone. ? If you have lag with the ATT your truck has a mechanical problem or it isn't tuned properly or you are one of the few out of over 100 plus people that have a special truck. Or you have an agenda.
I also spoke with a few people that have shaft play with the Hx clones you and Buddy have been recommending and more than a few have said they don't like the way the turbo falls off when the waste gate opens. Have more been having excessive shaft play?
Send 6.5 L your HX clone so we can test the clone on a truck that we have dyno numbers from the ATT, so they can compare the tubos on a dyno not just your butt dyno. Lets put up or shut up or are you afraid to have someone else do a test? I am sure many people hear would like to see 6.5l run the turbo on his truck
SO when are you sending 6.5 l the turbo to test? Let's do a real documented test without tuning anomalies?
Also my switchable tune seems to have lost the ability to recognize the switch from tune to tune. Just started to show up. The tunes either degraded or the programming is corrupted it has a glitch at a specific accel pedal and fuel rate in one tune then at different spots in two others, annoying to say the least. Had to ditch one of the chips with the switchable tune because two tunes failed.
Going to send it out to someone here to get it looked at. So at this juncture I wouldn't recommend it from my experience maybe it is just my truck ? just my observation.
