Big T
Remove the big BD actuator. Push/pull cable to a remote vac control.
Once you solve the actuator part of it, you could source the flange with butterfly valve from BD.
I'd spend the money for a drop in kit of the BD quality, not for something that requires new AC lines, new radiator, etc. The mods to make something like this work as a drop in for the 6.5 seem minor. I realize that anyone developing this has up front capital costs they must recover against uncertain demand from a dwindling and notoriously cheap population of 6.5 owners. The ATT has been a god send to the 6.5. A QSV for the ATT could take this to the next level. I just don't want to lose my AC or have to buy a '93 radiatior to do it.
Isn't it as simple as repurposing the wastegate controll to diverter valve duty with tune tweaks? Or am I missing something. Are there drawbacks to using one of these, such as stressing the engine?
There is actually A LOT to figure out about how to control it. The tuning part is unknown it is hard to say how changing the waste gate settings will affect the other parts of the tune. Then the arc of the arm and the rod angle for travel and the duty cycle. Full off at a certain rpm or boost pressure. Best that it is tested out thoroughly first.
Didn't think of it being closed at low boost unloaded highway speed. That's a real issue and further pushes towards developing a vacuum operated QSV. I know Slim is working on it and I'll place my trust in him.
Its a good point. I would also want it open while cruising to max my MPGs. Seems like it would be a choke point?
