Rockabillyrat
SlIgHtLy StUpId.
I sure amI’m not positive but I think our resident pump expert @Rockabillyrat is setup to balance injections
The Fluidampr is not a fix for imbalance, a common misconception. It is a device that protects against a wider range of harmful harmonics than a factory balancer does. Harmonics are created regardless of how the rotating assembly is balanced.It took 4 slugs of heavy metal to get mine right . Don't think you need a Fluidamper if the balance is tight . I just used a new GM piece .
