turbovanman
I has boost, :O)
Am I misunderstanding, cracking the injector line nut? Opening the line feeding into the injector and getting different results doesn't show a problem with the injector, it would be a restricted line or ip.
If you do suspect an injector, swap it with it another and see if the problem follows it. If just one is bad try disassembling and cleaning it.
I would try this first, would eliminate a few things. IF the miss follows the injector, then bad injector, if it stays, then IP or cylinder issue.
