GM Guy
Manual Trans. 2WD Enthusiast
Hey all,
I have contemplated re-installing the 108 gallon (I think 110 filled to the brim, rated for 102, or 108, cant remember, but definitely over 100 gallon) in the back of the 93 K2500, but am concerned about the legalities of it all. The tank is a single wall steel L shaped tank that the PO cut a hole in the bed and welded a fitting to the bottom of the tank, and had it ran through a sediment bowl and dumped right into the fill hose of the main tank.
is there nationwide rules, or does it vary state to state, such as I can legally run a certain gallonage and plumbing in one state, but cant in another?
I assume they want a suck straw from one of the top fittings so that if the hose was to get cut, you would hopefully shut it down? also I have heard 100 gallons is the dividing line between certain rules, is this true?
I will be out west (KS, CO, WY, ID, UT, CA, NV, OR) primarily, but on occasion might end up in the corn belt for a header, but very rarely.
any input on the rules appreciated!
(also, mods, move this OT if it doesnt fit here)
thanks!
thanks!
