Acesneights1
You're not wrong.
As long as he's running a 4L80E, it's all "tweakable" in the program:
That's an OBDII list, I assume OBDI would be similar. The TCC behaviour is also programmable.
I don't work in OBDI so you'd have to get a hold of someone who does.
My PCM holds the trans in gear longer for less RPM drop on the upshift and better performance while loaded down with the trailer. TCC behaviour is also modified.
I'm still not at the level of what Bill puts into his PCM flashes, but I'm getting close.
Of course, being able to tweak the trans and knowing what to tweak are two very different things.....
His truck is a 98...Is he running an OBD1 tranny ?
