ATT Install
There seems to be quite a difference in the turbo and exhaust mounting, would it be worth port matching them? Would it help spooling by eliminating some turbulence?Turbo123_1.jpeg Turbo123_1_2.jpeg
No. With GM's manifold design problems running the driver's side exhaust 90 degrees past two exhaust ports... It's the last step in a bigger redesign. The best spool advice is higher RPM where the turbo can spool.
