TurboTahoe
Recruit
- Messages
- 790
- Reaction score
- 6
Hi guys,
Just a reminder that those crazy OPS (Oil Pressure Switches) really don't last long (unless you put in an OPS relay). On the Tahoe, I knew that the Lift Pump was getting on in years (no idea how old it is, but judging from the looks of it, it's been many many years - it has a bunch of dirt and corrosion on it.) Well, I started getting the 'fish bite' symptoms at higher RPM while accelerating (around 2400 RPM). When I got home, I opened the fuel bleed valve, and sure enough, the Tahoe died. Since I put in a new OPS about 3 years ago, I thought to myself that it was probably the Lift Pump. I asked my son to read the multimeter while I lie under the Tahoe (while it is running in Park) and check - sure enough, there is 12V at the connector to the LP, but LP isn't running. I just assumed that the LP was dead, and I promptly ordered a new one from Bill Heath. It arrived in a couple of days, and I stuck it in (note: Bill gives great written instructions as well as those pesky little O-rings that would be hard to find if I just bought the LP from GM).
Anyway, I put the LP in, and then started up the Tahoe, and went to the fuel bleed valve again. Still quits. Oh no! It occurred to me that I didn't even do any diagnostics, I just assumed the LP was dead after my quickie 12V test. I picked up the old LP and applied 12V to it. Purrs away like always. I then apply 12V to the new LP. It also purrs. Well, looks like the 'not that old' OPS is dead - provides 12V to the multimeter, but can't do it under load. ARGH! I go to NAPA, buy their house brand OPS and plop it in. Sure enough, the LP starts running, no problem.
Anyway - the moral of the story is that OPS goes bad quickly, and I need to get cracking on the OPS relay, and that 12V at the LP doesn't mean that it works under load!
Thanks,
Rob
P.S. Although I have no fuel pressure gauge, my seat-of-pants dyno says that the new Health HD LP works great! No skips, no fishbite, no hesitation. Tahoe running great again!
Thanks,
Rob
