Well ,you should have the first tune in your mail now. And I'll try and get the one I'm building up done for you by next week to try out. His tune looks like it may lope a bit, so I'm reworking the pulsewidths and timing tables for the base tune to try and make it as close to stock as possible for your oversized sticks. Then I will build the DSP files off of that one. It takes a bit of time though to do a custom DSP5 tune file when you can't just use the basic scripts included in the software. I got a bit burned out earlier, so you can see in OT what the end result was. I started to post it up here and say I tried out your new tune for you.
