@21102k3500 Electric fans are rated at max of 5000 CFM freestanding. That is no radiator stack, closed hood, or engine in the way. I personalty measured a fan of a Trailblazer SS with wind speed readings on the radiator and averaged the MPH to obtain 10,000 CFM from this EV clutch fan in place: hood closed with full restrictions. The scream of the belt starting to slip was impressive around 5000 RPM. The same 21" TBSS fan put under the hood of my 1993 6.5 TD was NOT enough to keep it cool pulling a trailer in Lake Havasu, AZ. It didn't have enough "pitch" on the blades. Windows down, heater on high, No AC, SUCKS in 121 degree weather! The steel fan and Duramax fan have a lot more pitch and will pull way more than 10,000 CFM that, frankly, you can't get electric fans to pull. Pulling Lake Havasu with a Duramax fan and Kennedy Diesel low temp fan clutch allowed me to climb the grades with the AC on below 210 ECT.
This is why some fan catalogs note the 6.2/6.5/6.5TD as not recommended for electric fans due to not enough CFM.
Electric fans in front of the clutch fan are a restriction due to the windmill effect. Unless the blades are stopped and locked with a parking brake: running or free spinning the electric fan is reducing airflow.
The factory 6 blade POS fan and 20+ year old clutch one may be comparing electric fans too is no contest. The factory OEM fan clutch expired at 5 years old (they loose 200 RPM per year) and the 6 blade fan was a HO 6.5TD mistake from GM they corrected in later years. Many 6.5 engines went to china as scrap metal with the garbage 6 blade fart fan still attached.
Electric fans only help at idle for AC period and maybe. You would get better results with a 1100 RPM high idle and locked up fan clutch. The delay for the clutch to come on with a cold engine is another advantage of electric fans, again for AC only.
The only better than a Duramax fan setup with a low temp fan clutch would be a direct drive on/off fan clutch like Hummers have. This is mainly to overcome the delay in getting the thermal spring obsolete clutch to lock up after you go WOT and stay there watching ECT rise till the fan comes on.
