Anyone Running Either No Or Heavily Trimmed Wheel Well Liners?
Mad Maxx
See, what had happened was...
Long Island, NY
Is anyone out there running either No or Heavily Trimmed Wheel Well Liners?
I wanna know because I'm still having Trouble with Rubbing on the Backs of the Liner against where the Cab is.
I wanna see what ya'll did, and how Far you've made your Cuts.
And also wanna know if you've had any Problems with Water Intrusion from it or anything like that.
Very trimmed. No water can get in because all you cut is the fender, it can already get water in that from up higher anyway. No cutting into the cab.
Pull the fender liner out of the way and cut the pinch welded part off that sticks out there.Cut some on the bottom too, angle it in. That will let the liner go farther back out of the way. Screw it to the metal so it stays farther back.
If that isn't enough then you can cut the actual fender and the flare. I did that too. Mine is trimmed all the way back to the fender bolt at the bottom.
