Putting full flow on the bypass is no problem. You don't want to accdentally put the bypass element on the full flow is why I said to keep thread pitch different on the two.
Idiot proof it.
Idiot proof it.
Idiot proof it.
FS-2500 is a pretty good set up! :thumbsup:
If I had to do it all over again, I think I would go with a centrifuge setup. This way I would not be so dependent on unit specific filters of the FS2500. I would not have a problem with the Amsoil setup either. Most of it comes down to the packaging of the bypass setup. I do like the smaller, out of the way package of the FS2500. I like the even smaller footprint of the centrifuge setup.
If you ever generated enough oil pressure to explode a filter, I believe you would have other issues to worry about first
Also, appaently one of the best thing you can do on a diesel to preserve the oil is go with gapless rings. I'll be giving it a go on the next engine. I know joshua and others have said it works awesome.
Is it worth it do do a centrifuge in the garage, so cost of one set up and do multiple vehicles? Wondering about options, because it will not fit in the Hummer by the looks of it.
What do you mean? Buy a hobby one for fuels and then swap it onto each ride you drive? Seems like a boat load of work and hassle. I don't see why you couldn't mount one in a Hummer.
It is stupid tight in there, no room. I was thinking draining oil, CF to clean it then pour it back in. More work than just cleaning all the time, & dont know it would help having only a bit of cleaning time. I think i need to learn more...
Will, I missed it but how did you turbo your Hummer?
I really want to figure one of these set ups for helping the oil in my rig, but I have to do some creative engineering to fit some thing somewhere. What is the smallest yet effective centrifuge ? RI CHEVY got me to thinking on that a lot.
Removed engine, replaced all bearings, (without removing heads) oil pump, freeze plugs,cam- spun center cam bearing. While out drilled oil ports for center mount gm6. Custom bent intake studs for van intake onto truck heads. Mill center intake piece slightly for clearance under windshield support. Donor van engine for turbo and manifolds. Custom made 2 wire cps for signal to tcm and tach since ess style oil pump drive had to go. 2" downpipe about 3' long to existing exhaust to (all be changed later 4" exhaust w/ hmmwv style angled stack). Used injectors from van. 1/2 + up on fuel in db2. More power, same exact mpg. Higher egts in hot weather= overheating on freeway hills in 100* & up temps. Hopeful on bigger exhaust and new roof mount ac/ heater core set up will help. If not the water mist on non stop basis will go in.
