Can't afford shop labor to do this, but, not 100% broke -yet. Maybe we can work something out.
Have a shop borrowed and my replacement engine/trans/transfer case on a pallet from my wrecked truck. Has a resealed transfer case and rebuilt low mile transmission. Bolted to the 6.2 engine with very low blow by, low mile injectors and a good IP.
Current engine has bad blowby and a near dead IP. Advance piston stuck... Transmission /transfer case seal leaking but both are good. By bad blowby I mean a road draft tube makes the truck look like it is on fire! :sifone:
Will need to transfer intake manifold, fuel manager, water pump backing plate and converter rock guard..
Rest should be in and out.
