indybeck
Has anyone had to remove a evaporator core from a 96 GMC? Well, here are some pictures. I wouldn't recommend it! LOL But mine did need a good cleaning.
You must not have any women that ride with you! LOL
Wish I had asked BEFORE I started! LOL
That is absolute insanity that all that has to come apart to reach the evap core.
The engineers must have been using Meth when they designed it.
One thing about it, with iot down that far, I would sieze the oportunity and replace the ignition switch, brake switch and anything else thats handy while I was in there.
MGW
steering column does not have to come out, just push seat back as far as it can go, remove support braces, tilt steering wheel up as far as release will let it go lay steering column into the seat.
Dash rolls down on pins and gives access to the core, it is a PITA took me about 14 hrs 1st time
I've never done a GMT400 dash yet, but done MANY a DODGE, JEEP, and CHRYSLER and I've never actually pulled a dash all the way out. I normally drop the column down as far as it will go and then swing the dash out and lay it on the seats. I was told that the GM dash is alot easier to do than most of the JEEP dashes I used to do which would take me about 2.5-3 hours. I guess that RANGER I just did the other night was pretty easy as it took me about 20 minutes to have it out. Many of your imports are also pretty easy to do as most of them are set-up as an add on unit that pops out like a module once the glove box is out.
I did a 1998 Dodge, then a few weeks later did the GMC.
Never done either before - Dodge was 8 hours, GMC 12
