88gmctruck
02GMCtruck
Yep, not a problem. I'll just have to help you make apple pie to make up for it....
Its been down for about a month an a half total since school started in late august. First the vane position sensor, then an amp, and now the pitman arm. I hope that's all for the year.
And I hope you are enjoying the full tank of gas I left you in the yellow truck.... Thanks for letting me use it
I pull large loads and do 1/4 miles...I just wonder how those 50 or so launches are affecting them...I would figure they have to be just as curious as I am...
Now I am not too familiar with specific lift kits, but If I remember correctly, I believe both 07HDClassic and schulte have Fabtech lift kits on. Does the fabtech kit change anything that has to do with the steering? just a thought.
Btw, I am glad it only happened in a parking lot. I've broken a steering knuckle on a Jeep out on the trail and remember thanking god it broke there and not on the trip home on a highway.
Keep us updated. I was about to purchase all new steering for mine including the Cognito kit.
My guess is what Nick is finding that if your steering box is "loose" and has play it is a good chance that's what the cause is...so what I'm going to do is have my steering box play checked by a mechanic and if it has play I will either replace it or remove the braces...I've only run 285's and now 265's... but...my truck is also 9 years old...
