ShawnR
Find out what a machine shop would charge to fix the cracks using the Lock-'N-Stitch system..
This is the 2nd crank with this block already. I think it is jinxed.
This has just about convinced me to fork out the $950 plus shipping for the forged Peninsular crank for my upcoming rebuild. And yes I called them and its not a myth , it is really available
Yeah, I remember - was just funnin' ya, TD. Rich posted some cool pics of the chips in his block, the busted crank, and the crappy way the whole thing was packaged on that pallet.
There's a lesson in that for people... check every shipment for damage before you sign...
I found a 2000 506 instead, -built that one, -and broke it with the shop-rag in the intake.
I just got off of the phone with Bill Heath and he confirmed that a 6.2 shortblock will work fine as a replacement for my busted 6.5. He said to be sure to use 6.5 turbo head gaskets with it and everything else should bolt right up.
I am planning on picking up a supposedly low mileage (50K) 6.2 in Cleveland in the next day or 2 for $200.
<snip>
I will check the rocker retainer clips while I am in there.
(Thank You!)
You got the time right I think you should swap the heads as planned if you can, and get a high flow water pump and updated DMAX fan while you got it all out. A pump off of a 97-98 truck or one from SSDieselSupply or wherever. You'll need the intake to connect to the turbo.
The 6.2 with 6.5 heads and turbo with updated cooling should make for a better more reliable towing truck, since it has a stronger block.
