This is something I did today. I took Tdoc's advise and made the LP line a striaght run. To do that what I did was to make a bracket and mount the new filter and LP to it. I will need to drill one hole in the frame for the new bracket the other hole will mount under the existing LP bolt (top bolt).
The barb on the right of filter is the inlet (in this set up) and will attach to the line from the tank via one of the LP Bypass Fittings.
The top barb on the new LP is now a striaght run and will connect to the line going to engine via the other fitting in the bypass kit.
