This is another first for the 6.5 trucks. If you want to install a aftermarket lift pump (LP) and/or filter these fittings will allow you to do it without cutting your original lines. These fitting are exactly like the female ends of your stock LP and have a 3/8" barb on the other side. I looked for these everywhere but could not find anything that would work, SO I'm having some made. These are quite uniqe fittings because they are metric threads and have an Oring seat. With this kit you don't cut your lines and in an emergency you can easily put your original LP back in. It's good to know you will be able to use over the counter parts if you are in a bind or away from home....ect
I will be selling for $19.99 for a set of two.
www.pmdcable.com
Close up of fitting
This is a example of what you can do. The two special fittings are to the far right. Right of the filter. Imagine inbetween the new fittings is where your old LP would be.
I tried to load 4 pictures but they failed to load. I give it a try in another post.
www.pmdcable.com
Close up of fitting
