razur65
So, after finally had enough of wheezing, gutless wonder towing runs, overheating pulling up hills, mysteriouly leaking coolant with no puddles or signs of fluid and generally every typical complaint echoed by failing GM 6.5 diesel drivers... I put the beast in the barn for a tear-down.
Pulled the front end and radiator support, inner fenders. The harmonic balancer was new 5 years ago, needs replacing again.
Compression test numbers I thought looked good, most cylinders nearing 400 PSI, only a couple in the 340 range.
Leak down test was disappointing, started on left side (driver) of block, all had leakage could hear blowing into crank case.
Right side was catastrophic, could feel pressure blowing out the intake ports on the head, end cylinder #8 was totally blowing out intake port.
Pulled right side head, I expected to find cracks and was not disappointed, found between every valve!
Prolly find same thing in left head, not sure what direction going for this motor, was hoping to redo top end, heads, injectors, turbo upgrade at least, and rebuild transmission with heavy duty plates. As always, best laid plans, etc, etc...
