Missy Good Wench
Wild Blonde from Cloud Mt
Well as they say, ALL good things come to an end.
My 95 dually Crewcab 4x4 "DaHooooley" finally gave up the ghost the other day.
Started loosing coolant but not pressurizing the cooling system.
Further investigation revealed the leak was into the crankcase
Started ripping the beast apart last weekend but not quite done yet.
The weather has been crappy so the engine is still in the truck.
One more nice day and I can get the sucker out and into the shop.
I decided to get a leg up on the issue and scrounged up another block.
Got a nice 929 block in good shape.
The cylinders has a little etching in 3 holes so its getting some new .5mm slugs in 19.8:1 form.
Once clean we found one tiny crack starting in the outer hole on #2 main.
The starter bolt holes had been molested a bit due to bolt breakage but this was easily fixed with a pair of Helicoils.
This weekend I set the block up and installed the "Full Torque" inserts from Lock and Stitch on all six (6) center main outer bolt holes.
This done the engine is now back in the machine shop for boring and having the decks machined.
Should have it back soon.
A good friend brought over a nice standard crank and I had a set of fresh 6.2 rods.
Going to have the rotating assembly ballanced just to make life better.
I will likely install a fresh set of heads from Clearwater to top this build off.
Used a set of these heads on my 94 Burb 3 years ago now and all is well.
Once the engine is out of the truck the true tale will come into view and I can see just what happened.
Will use all that I can off the old engine to finish the new one.
Just not a great time, but at least summer is on its way and the weather will be nice to work on the beast.
All for now
MGW
All for now
MGW
