From what I've read champion is china built stuff. Some of it is really good while some of it is not so good. The jeep guys seem to talk highly of the 2 row models, but they made a 3 row that was a nightmare failing left and right. If the champion one for our trucks is anything like the mishimoto in quality, I would pass. They've had alot of problems with electrolisis, and corroding through after 2-3 years.
If electrolysis is the only problem- that is actually a good sign of conductance. Bad for you on the electrical side, but that scientific number is exactly the same for thermal conductance-which means it can shed some serious btu's.
How it is built, how well the seams and joints hold up, how good the air and water flow is - thats what to find out.
So that overly expensive Mishimoto is not a good radiator?
I started to buy one when mine started leaking, so I dug in and did some homework, and quickly decided against them. I ended up lucking out and fixxed the leak in mine.*Now* you tell me . . .
Maybe the Burb will get lucky seeing as it not using water :/
I've seen a lot of talk saying distilled water has a high ph level and will eat aluminum.
Running Evans, probably be fine then.
NOPE! Distilled water has a pH of 7, which is neutral. Exposure to air will cause distilled water to pick up minute amounts of CO2 (Carbon dioxide) from the atmosphere, which disolves and becomes carbolic acid making the water very slightly acidic (pH 6.9-6.8).
Minors in Physics and Chemistry, University of Nebraska.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Of course tap water can be the death of radiators due to electrolysis because of the disolved calcium and manganese ions ("hard" water) and carbonate ions make it electrically conductive.
Radiator anode? Already been done 40+ years ago. JC Whitney used to sell a sacrificial zinc anode that hung off of the bottom of the radiator cap into the radiator. Oh, the joys of being old with a memory like fly paper. Fly paper, what's that, asks the young 'uns on here. LOL!
