Will L.
Bison hooked up the provent backwards. Wish I was around then to have helped him. Only pointing this out for future readers to know. The valve cover tube should have went to the top and the vacuum side (turbo inlet tap) goes to the bottom. Look in the picture I post and I am pointing to an arrow made into the provent which indicates direction of air flow. Also you can watch this video from the mfr and notice which one they connect the valve cover to.
This is why Bison always had pressure, and what he probably wasn’t aware of is the coalescing filter would not work anywhere near as well as it should have. I would be amazed if it removed half the oil it should have.
