bjelder
Here's the deal. Took truck in to have it scoped because I have recently been having the tranny go into limp mode last year three or four times throwing a Po735 code (5th gear ratio). When scanned it showed only that code. I was told the tranny needs to be overhauled, which I expected and saved to do anyway before final purchase on fifth wheel. Reason being my wife and I are going to be full time rv'ers pulling a fifth wheel which will weight between 15,000-15,500 lbs fully loaded and wanted to upgrade tranny before we start our venture. Truck is 2001 lb7 diesel one ton dually to bring you up to speed on that with the Allison transmission. My question is to do a rebuild or remanufactured replacement? Again other than possible the c2 and c3 disk likely burnt and not enough solenoid pressure to hold disc the tranny is awesome. There is no problem driving it daily, as code only throws when pulling my 17' aluminum boat and trailer up a hill which together doesn't even weigh 2000 lbs. Any advice on rebuild or remanufactered would help. Thanks in advance.
Jim
Jim
