Ed HD
Formerly: Dad's 05 LLY
So we are finally getting around to plumbing our shop with compressed air, because this spring we bought a large compressor (~80 gallon tank, dual cylinder/stroke 7.5 HP compressor). We decided to go with a setup using polyurethane air tubing and push to connect fittings, due to the cost and ease of running. This whole setup is gonna cost $650-ish, metal pipe or other tubing would be expensive, and harder to cut/run/deal with, and the plastic isn't really affected by weather changes. I'll be sure to throw up pictures of the whole deal as we go.
The plan is to have 250' of tubing with 8 drops, 2 to reels, 6 to fittings inside the shop over benches and to key areas, 1 out front and 1 into the shed behind the shop, with valves to prevent freezing/exploding on the outside/shed ones. Tubing is 1/2" OD and will be run with 1/4 NPT fittings. We don't need any larger for our use. We are going to have to run the tubing into a small section of metal pipe at the end for the drops that don't go to reels, as the tubing and fittings won't be able to support the weight of a hose and quick connect fitting, no matter what kind of attachment we use on them. Metal pipe will be able to be firmly attached and hold the weight. Might look odd, but it should work great.
Tubing: http://www.lubromation.com/product.php?id=2434
