The hood cowl seal does one very important thing for you: it keeps carbon monoxide from getting into the HVAC air intake located below the wipers. (And thus the cabin.) Even with a bad one I can smell when I get an oil leak on the turbo. So removing it may make more of a difference than a bad one, but, these are an important and often neglected seal. Our 6.5's have several possible exhaust leak areas on manifolds that are supposed to plug with soot.
The under hood air temps are always higher than through the fender. The temp increase from a under hood hot air intake gets noticeable when the engine fan kicks on. GM would rather use under hood air to keep the snow from plugging air filters. However using under hood air helps overheat Duramax engines working hard. This is interesting to follow the trade offs from cold air intakes vs. snow plugging the filters. Some plug to the point the air filter went through the turbo. (Why do you think the 2008 Duramax replacement air filter now has a "X" built into it to help stop this.) GM has forgotten the thermostatic air cleaners of yesterday. Hot air affects MPG and derates your engine power.
K&N is simply old technology that has been replaced by modern "paper" filters. To add insult to injury there are even better reusable dry filters out now. You buy a filter to protect your engine - not for extra power. If you want power only just leave the filter off... It is what K&N marketing appears to do.
