BigBlueChevy
Compression Ignition Addict
There was a test done using quite expensive equipment and over the course of a few days that involved all the major filter brands like K&N, S&B, Wix, AcDelco, and... a bunch of others. (I really need to find the article). Essentially all of the filters where run through a series of differernt tests such as filtration percentile, flow in water, flow in air, and flow as time goes by with "crap in the filter"
Essentially the verdict remained true that K&N is one of the worst filters to own(again this is based on the test results.) Suprisingly, AcDelco's filter had the greatest capturing percentile of particulates, best flow in both water and air, and maintained the highest filtration and flow in severre conditions(sandy, dusty generally places you want the best filtration possible).
In reguards to filtration, I would personally recommend a filter of equal, or greater size than the stock cylinder filter in the 97+ trucks. Reason being, if your sucking in 300cfm of air through a filter that is 150 cubic inches squared, your going to want a filter that is equal to or larger than 150 cubic inches squared. If you go and buy these "cone filters" that seem to be the "big thing" right now, you are effectivly reducing the area in which air can be drawn in. Instead of 150 cubic inches squared, your using a filter half that size, lets say 75 cubic inches squared.
Now, instead of sucking 2cfm per square inch through X brand filter, you now sucking 4cfm per square inch through Y brand filter.
Again this is really just my own observations and calculations. There is no "approved" theory out there by some college buff that states what I just did(that i know of) Just a younger guy running his mind finding ways to further improve an engines capabillities. Also, the numbers i used are just... numbers. Not actually flow amounts.
