Dan Hunter
Truck Terrorist
I'm about to start prepping my truck for a utility finish. My original blue paint is coming off and the green camper top I recently acquired just don't look so hot together.
It's getting a coating of Parker Duck Boat Paint, Bay Gray. I've done this before on a 84 Chevy gasser that had a red bed takeoff and mismatched fenders. It turned out fairly well but I want to step it up.
I'm looking for practical advice. This is the advice I found on their web site.
FINISH: Flat
SUGGESTED DFT: 2-4 mils
VOLUME SOLIDS: 46%
FLASH POINT: 104° F. (40°)
THEORETICAL COVERAGE: 738 square feet per gallon per dry mil
DRYING TIME: To touch: 4-8 hours at 75° F., 50% R.H.,
Re-coat: 12-24 hours @ 75° F., 50% R.H.
RECOMMENDED THINNER: Paint thinner or mineral spirits
SURFACE PREPARATION: All surfaces should be clean, dry and free of all dirt,
grease, oil, loose paint, rust and other foreign material.
Glossy surfaces should be sanded or de-glossed.
MAX. SERV. TEMPERATURE: 200° F. (93° C.)
RESISTANCE: Water – Very Good (not for constant immersion service)
Wearing – Very Good
COMPATIBILITY: Self priming on wood. Prime aluminum, steel or fiberglass with a universal primer (300 Primer).
APPLICATION: Apply brush, roller or spray.
Airless or HVLP spray:
Airless: Use a fluid tip with .015” to .017” orifice is suggested at 2500 psi.
HVLP: Use .051” fluid nozzle, #10 Air Cap.
They mention thinner but not a ratio and I'll likely contact them about that.
Prep-wise, I'm going to start removing trim this weekend...fender trim and bump strips. Anyone pulled the bump strips before? Advise?
I'll also pull all the parts that I don't want to mask...bumpers, grill, whatever. I'll form a cover for one tire and then move it around to the others.
I'll be following GMCTDs advise to lay down and pull up duct tape to get the sheets of loose blue paint off. Since the paint is self priming - and really adhered well last time I did this - I'll probably block sand with 320, scotchbrite it, and wipe it down with denatured alcohol or something.
Last time I masked, I taped together grocery bags. Where can I go for something better?
A buddy is going to let me use his barn. Should be good enough to limit impact on the spray pattern and any dust will just add more character to the flat finish.
Really, If you've read my posts you know I need help. Any advise would be appreciated.
FINISH: Flat
VOLUME SOLIDS: 46%
Wearing – Very Good
