- Staff
- #21
Good point, one needs a Demulsifier.
Been running B5-B20 since new. Almost 100% BIO in illinois... We are, after all, one of the biggest soybean producers... But in winter it's likely no higher than 5 because BIO gels much easier and why every tank gets additive when temps are below 30.For lubricity, good ole biodiesel is best.
Add about 1 gallon per fillup.
Both petroleum diesel and biodiesel attract water, not a unique problem. They are equally at risk of the black slime as well (from sitting for extended periods with perfect climate conditions), which is not common.
Better filters than stock is something that I'd consider mandatory with any engine you want to get a long lifespan out of. Manufacturers spec the filters to get the mechanical components to last to the end of the warranty period or expected lifespan (10 years).
A B5 to B20 blend of soy pumped into MILLIONS of trucks of all sizes here in Illinois for the last 10+ years with virtually NO problems says BS on your analysis WW. Maybe in AZ but uh uh here.
This first part is completely incorrect. The phrase opposites like oil and water... petroleum diesel is oil- a specific grade of it.
If you take petroleum diesel that has not had an emulsifier added to it and add any percentage of water. You can mix them up with a blender. Then simply let them sit. The water will seperate from the diesel at a level of 99.5 percent based on temperature/ dew point/ relative humidity.
If you heat it to 195*f it will seperate at a level of 99.999%
It is only since the reduction of sulfur in the fuel and the related btu drop that the addition of alcohols into diesel fuels became “normal”. These alcohols added soley for the bump in power emulsifies the water into the fuel. The higher the content of emulsifiers in the fuel the more water it will absorb both in mass and proportion.
I have been out to make equipment purchases from oil mining and refineries in Northern Nv that had trace amount (to scale) in massive tanks and equipment. We wereallowed to have about 40 gallons of #2 diesel that was produced back in the late 90’s. That location got deep snow, and descent humidity. Condensation in the tank had water sitting with the puddles of diesel, but was fully seperated. We used the old fuel for some testing practice. Being that old in the presence of water had no effect because of the high levels of sulfur.
Great chart. Where did you find that?
Great article..........thanks, I'm dealing with diesel fuel in one tank that has sat or 2 years.Diesel fuel with bio can have a low six month storage life. https://www.yachtingmonthly.com/sailing-skills/how-to-avoid-diesel-bug-32632
