JMJNet
Recruit
This is some pictures from installing AD244 Alternator to replace the small CS130 in a 95 (Driver Side).
Just to give people some idea if they want to replace the stock alternator.
There is a lot of thread on replacing the CS130 with CS144 and in the thread, TheFermanator always said that AD244 is a better replacement.
So, with the CS130 alternator started to get weak, I decided to put the AD244 alternator.
AD244 is relatively thin and it is about the same thickness as the CS130 with a larger cross section diameter.
It is only a slightly heavier than CS130 but it seems that the removal of rear bracket is not affecting anything.
AD244 has a plastic looking rear side for heat dissipation with a heatsink regulator.
It is actually a fairly easy replacement.
All the rear bracket is gone.
The bottom bracket lines up perfectly and it uses the same bolt, it was a 3/8"-16 bolt.
The side bracket have to be reversed as suggested by Leroy (Burning Oil) in his build thread.
It is a 10mm or 3/8" bolt hole so the hole in the original bracket have to be enlarged a little bit from the original 8mm.
I used a 10mm bolt for the side bracket with a few nuts and a fender washer.
The connector have to be replaced with the oval style connector (same as 96+ with CS130D).
So far, voltage stays close to 14V with loads (AC, headlights and stereo all on).
Here is the pictures of the install.
