Big T
Bought the '99 in January and had no need for AC until now. Well the AC pumps out heat. I put one can of refrigerant in the system and no change. I guess I'm better at engines. Where do I start to trouble shoot this?
Did you even put guages on it ? Is the compressor clutch engaging ?
If the compressor is not kicking on you would be unable to charge the system. I mean some would go in to the equal pressure of the can you are charging from but if the compressor is not running it will not "sucks" the refrigerant into the system. Put guages on and see if any charge at all is in the system and then if there is Jump the cycle/hi press switch at the drier with a paper clip and see if the compressor engages. Report finds back.
You have to pull a vacuum on the system before charging it if its been sitting any length of time. Air is a non condensable, your compressor cant make it change phase into a liquid, so the AC will never get as cold as if you got all the air out.
The smaller the system, the more sensitive it is to the state of charge. You really want your suction side at 30 to 40 PSI, that should get you 35-45 degree air at the evaporator. Dont go lower than 35psi or you will just ice up.
You should also be keeping an eye on the high side of the system. with the low side at 40PSI, and it being 90F out, High side should show around 180 PSI. If it shows more, you need to get the water and or air out of the system.
Prolly way more than you wanted to know, but I do this for a living ):h
China Tool and Freight
This will work if your not going to be doing it every day.
Did you check to see if there was anything in the system prior to topping it off?
So long as there is always net positive pressure in the system, you should be fine to just top it off. I always had trouble with the long ass lines to the rear seeping refrigerant out through the rubber hoses.
