Big T
The dash AC / Heat blower mower stopped working on my '99 Suburban. Check all fuses inside the cab and in the engine compartment and they were good. Rear AC works fine. No sign that it was going out. Last work I did was resetting the turbo to downpipe band clamp, replacing air cleaner and fuel filter. Any possible wiring to disrupt in those areas? Or is this just the switches going out? If the latter, how do I test? Do I have to pull the stupid dash down to fix?
Man the AC was working great, very cold. Still is on the rear. At the lowest setting the blower did have a feint squeek in it, but it disappeared at higher settings.
