Woody35
Active Member
other things are in the works as well that may enhance our performance. We are not done yet.
i like the way your talking. i want to put off buying a duramax for as long as possible
Need a few thousand more miles on the engine before I can get at it and put it on the rollers! The trip to Bonneville will give me the added miles. So it will be October for me also. The dyno shop nere here is $90 an hour and I will be on the rollers for quite a while. First test with the GM8, second with the A Team Turbo, and the third test will be with......................?
Other than $$$ do you think theres any performance gain with it?
with what an ATT ? if that is the question, yes is the answer,
How much I've never run it on a dyno or against a timer on a track to quantify the improvement, but take a ride in an ATT equipped truck with a reflash and you will notice it's got the goods.
That said the ATT was never built for perfomance, it was set up as towing improver, but side benefit is that when empty you have some decent performance gain as well.
Would the current ATT be "upgradeable" to ball bearings?
NO, and I am not sure that there wil be a ball bearing turbo yet, I may have ot pay for an engineering change and I am not sure how much that wil add to the turbo cost, I don't think the ball bearing option would add much more performance. There are other things that will add more power for a more reasonable cost, that is in the works , proto type is almost complete.
I was going to get one but I'll wait for the result of the trials on the prototype. Thanx for the heads up on the prototype.
There will not be a change to the A-team Turbo, and I doubt that the ball bearing cartridge will be a production run any time soon if at all. There is not that much of a gain to be cost effective.
The proto type I spoke of is not a turbo upgrade or a turbo, The proto type I created is of another part that will possibly give our engine better performance and fuel economy. This part is a long way off from becoming usable as of yet. So if you want a turbo buy one when you can.
