A question to all the diesel guru's in the crowd!
Yup pre 97 run of the mill 6.5, not no dual t stat, and ac compressor on pass side, S engine RPO code L56 should be on the sticker in the glove box, need to scrape off the Cat badge go by Hummer dealer or online somewhere and get a more appropriate 6.5 badge
TD, what do you make of their 400HP claims?
In a marine engine with unlimited cooling that is going to be set at a peak load rpm setting, with proper fuel delivery, and addition of a SC and intercooling, I'm thinking not out of realm of possibility for 400 flywheel Hp, remember Heath land speed racer twin turbo is estimating 500 flywheel Hp.
Yep - regular old 1500 Yukon....nothing CAT about it....
Nice looking unit though!
Realized I forgot to say nice truck!! Looks like fun 'little' ride!! I bet it gets out of its own way in a hurry, and fun to drive!
It is a nice ride, I wouldnt mind having one but I would really have no use for it. I seen one that was black at a stop light, it looked like it just rolled off the lot. Looked all stock but in pefect condition.
Maybe some day I'll get one for a run around rig.
Need to get after that heater hose connection B4 you lose the engine to lost coolant - simultaneously get after that PMD: should be a remote-mounted FSD B4 the end of today - also see something strange down between the ac comp and the waterpump - then, go over all the connectors and grounds, make sure all is functional - need to perform some severe ablutions on the general engine\engine bay, while yer at it.............
Yeah they are fun and get out of their own way pretty good. Got a long list of mods for mine when I get back from Italy in a few years. Top of the list is full rebuild of engine and tranny with a tranfer case swap and solid front axle.
Right now it is the best road trip vehicle I have ever owned. Just hit the highway and set the cruise and it stays right there for 500 miles or so and is an absolute pleasure to drive.:thumbsup:
Yes, I know I have ALOT to do under that hood as screwed up as everything looks. First and foremost, I have to change the flywheel.
