jrsavoie
Recruit
Greg, you may still want to consider the lift pump/OPC relay update.
Uneducated 6.5 preschooller question alert!
Why wouldn't the LP always be on as soon as the key cycle starts (and WTS begins)? Dumping over relief until it's needed.
On my 96 (OBDII) lift works with key on, untill WTS after glow has finished then LP stops.....Normal?
Yes and if you had the filter mgr drain open it would run a little longer as the pressure sensor in the lift would be trying to run pump long enough to build to cut off pressure, (not so much a pressure sensor, but a current monitor circuit in the pump for how much extra draw the pump sees when pushing against a head as pressure builds when not being used)On my 96 (OBDII) lift works with key on, untill WTS after glow has finished then LP stops.....Normal?
