gnel
I don't think you would have a problem doing this temporarily. Try bypassing the passenger side injector returns. Run tube from just after ip and to the return line going back to tank. Put a catch pan on the line from the injectors as they will still be returning fuel too. This would tell you if its the pump or one of the injectors or the hoses. This to me would be easier then if it clears up you can test like AK suggested to isolate the issue.
Thanks for the reply Leroy. I´m into easy. Thanks. gus
