gnel
Let me start by saying these questions have come about since I had my IP rebuilt and I installed it. That was a couple of weeks ago.
Today I finally put some clear return lines on my sub. No bubbles from the IP to the hard return line but lots of bubbles from the passenger side return line
. I must of done something to the rubber return lines? I am not seeing or smelling any diesel and the truck runs fine. Is this something I need to repair right away or ever? Can this damage anything?
My next problem is that since I installed this rebuilt IP I´m not getting the same boost #s I was before. I haven´t seen more than 4. My vacuum numbers are spot on but I can move the wastegate manually at idle. Its stiff but movable. Could the recalibrated IP not be comunicating correctly with the computer? Please bear with me as this is the first diesel truck I have owned with an electronic IP and a computer:???:. Thanks for any replys. Gus
