needa
here 4 knowledge
i just bought a new a/c compressor because the other was seized. after adding in the 4lbs of freon and a couple cans of oil, i finally had great a/c. this lasted for 2 days. after shutting off the a/c while it was blowing cold, there would be this huge release of pressure into the system. <-- only way to describe the sound.
i looked around for leaks (dust caked on oil spots) and hooked it up to a vacuum. it held up to the vacuum.
any ideas?
also, at sturtup, when i take off.... there is some hesitation to the point of it trying to die. after it gets going, its fine. and this doesnt happen all of the time.
last question.
is it normal to be towing a 6500 lb travel trailer on the interstate and only be able to barely get to 65mph. and slowing down 10 to 15mph on the inclines. i live in nashville, so not to terribly hilly.
thanx a ton,
-patrick
any ideas?
last question.
thanx a ton,
-patrick
