MoldyCouchPizza
Just recently acquired a 99 chevy k2500td with 140k miles on it which wont start (friend was driving fine down the interstate and engine cut off, no CEL, and loss of power steering). Considering the PMD/FSD mounted on the IP was the stock position (IP was replaced with a rebuild less than a year ago) I assumed that the rebuilds PMD was fried and ordered a new one, a spare to keep in the glovebox, and a remote mounting cable and heatsink. Alas, after hooking all this up and cranking it didn't work :-( Distraught, I checked to make sure the lift pump was lifting fuel out, and the injection pump was squirting fuel, both of which were happening. Glow plugs were just replaced less than a year ago, so I've been scratching my head on this one! OBDII scanner says voltage is at 13.2, which I read is a bit low...
I've been reading through the 6.5 grounds post by TD, and tomorrow will clean all the grounds... Fingers crossed she'll come on! Any suggestions will be much appreciated, and I will be reporting back along the way in case anyone else has a similar problem and comes across this in the future, thanks!
