Acesneights1
First off don't panic about checking the timing on all 3. People here take the timing way too seriously when it shouldn't be...OK what I mean by that is everyone strives for -1.94 because Bill Heath determined it's the best place to be and it was discussed vs the Optic Bump yada yada yada...In real life for the average Joe just using his truck for work commute etc there is a fairly wide range of where the TDCO is considered acceptable by GM and it will run fine so don't panic. Of course if it's out of that range, then yes it should be adjusted however it would probably code if it was horribly off. Fishbiting is genrally PMD. Never assume that..we did this and it can't be that. Shit like that happens to me EVERY frickin time. I would clear all the codes and then if the SES comes back on post what new codes you have and we can go from there. You know I have said this many times if you own one of these trucks you should own a spare PMD cause I don't give a hoot nanny what you do or where you mount it or what brand it is, these things fail at random. I have owned enough of them now to know that..If I am reading your sig correctly you own 6 of these so you should definetly have a spare PMD. Now in your first post you said you switched PMDs. What is the status of the "spare one" you used. Was it new ? a "good used one" from Edam etc etc. Fix the boost problem as well but also have you cleaned all the electrical connections ? They can cause really weird stuff to happen...
