GM Guy
Manual Trans. 2WD Enthusiast
return line off the top of the pump to check for air, yes. that is the line. so 1/4 inch then?
air in fuel will cause it to stumble. saw one recently that only had air in the system at about 2k plus rpm. no air at idle. it also held 3 psi at the same time. bypassed the entire fuel system and still had air. evidently a failing IP can make it's own air.
a bad crank sensor won't cause it to die as it will run on the OS. it can make it stumble buck and snort in no particular order tho.
Did you ever look at the 'last ditch screen' to see if it plugged on the IP making it's own air?
well folks, she is fixed!! (in this issue anyways)
Before I got too wild, I remembered that the fuel lines would still rotate even with the fittings torqued.
All it turned out to be was a mis- machined Delphi lift pump that the PO installed. Ran out of threads before it was tight, so it was sucking air around the fitting.
I didnt even change the line, installed a new AC Delco made in USA EP158 LP, and problem solved!
Love it when its simple!.
I assume being an auto it's your winter salt sacrifice?
