Husker6.5
Either a break in the switched terminal from A/C ON-OFF switch to the + side of the relay's coil, or a bad A/C ON-OFF switch easy enough to trouble shoot. Run a LONG jumper from the N/O side of the A/C ON-OFF switch to the + of the relay coil. If you turn ON the A/C and the coil engages the relay and your A/C system comes on - you have a break/bad connection somewhere in the wiring harness between the Dash A/C switch and the relay to the A/C system. If the coil doesn't engage the relay and turn on the A/C - then the dash A/C ON-OFF switch is bad.
OR:
You can pull the connector off the dash switch and then put a VOM on the hot side and to the load side of the switch and see if you get 0 Ohms in ON position, if so, switch good and use the LONG jumper method to see if harness/connector is the issue. If you get Infinite resistance, then you know the dash switch is bad and then if you put in a new switch, check for harness/connector issues with the jumper!
OR:
