1998chev65td
Do you offer tuning services?
Hey sorry no I do not we do live tuning at our shop on our Dyno sorry
I am curious as to the condition of your turbo? is the shaft play getting bad, or what was the failure symptom?
Wow talk about leaving out the details of your truck. That'll make a difference lol
Ya I know I said tires to but the weight of my new tires and rims are lighter then stock wheels and tires so there is no worries I worked at a tire shop for 6 years when I was in schoolHaha, no I think he means the bigger tire size.
Well of course it would don't worry about gearing I didint ask for thatYour tires are 6" taller than stock. That makes a decent difference in gearing and how the turbo spools up by the load implied and the rpm down the hiway.
Then planning on going to a higher stall tc on top of it.
That has a bearing on a turbo spooling and where it lives in the rpm band.
2 thoughts the ATT with a quick spool valve or a real hx40 with the right wheels
What is a quick spool valve? I'm not familiar with this. Does it make the ATT work better at lower RPM?
I'm thinking the ATT would probly be even more advantageous with a 5 sp like mine, better control of RPM to keep turbo in the power band. I had come up with a gear venders overdrive that I had planned to install but am wondering how this might work with the ATT. AS gear ratio gets taller with overdrive rpm drops and boost falls off because ATT will drop out of it's power band?
