Staufferjake
- Messages
- 15
- Reaction score
- 37
Is 94 6.5 diesel compatible with the motor mounts on my 98 that had a 454. And will stock Trans bolt up
With enough time/money anything is possible. Details. We need more details. 2wd or 4wd from donor to receiving vehicle. What do you mean by "bolt up" for stock transmission? Will they physically mate or are they electrically compatible also? Frame/motor mount-wise, yes the the two will interchange, use new motor mounts, though. You are also swapping across OBD-I and OBD-II computer systems doing this. And most importantly, WHY would you want to do something like this? Just rebuild the 454, you'll be much better off.Is 94 6.5 diesel compatible with the motor mounts on my 98 that had a 454. And will stock Trans bolt up
As long as you can install the correct sensors/senders on it for the 98's computer, no problem. It may just be as simple as bolting on and using the newer intake manifold on the older motor so that you can use the correct throttlebody and MAP sensor for the computer to "see". You get what I'm saying? Or using the later, OBD-II three wire sender that will screw into the hole the earlier, OBD-I sender screwed into on the older motor you're using. This isn't specific, it's just examples of things you may have to do to get the older replacement motor to work in the newer vehicle, understand? Like using all the accessory brackets and the alternator and A/C compressor for the 98 on the donor motor.So if I stick with the 454 does it have to be in the 95-98 Era or will older motors work because of the obd issue
It would be nice if You could start a thread about the progress of this project.I wanna thank you all for the input on everything for my build
