- Staff
- #21
$1700 is outright RAPE to replace the sunshell. It doesn't fail because of OD, but when it goes you lose 2nd, 4th, and reverse. The A/C compressor is a common failure point on the R6 compressor, and that was a pretty high bill even for a stealer to replace one. The upper intake gasket set was just because of the regulator, but in all honesty they should have just put a spider in it(typical stealer bleeding the customer). Sounds like it still has the origanal intake gaskets, and with you saying it's been using coolant, my bet it has been going into the engine. This COMMONLY wipes out bearings(pretty sure I posted about that AWHILE ago warning). The tap on cold starts can be lifters, but in my experience it is normally oil pressure slow to build from a plugged up oil pump pickup. The compressor issue can be fixxed as well with an aftermarket compressor with a pinned housing. The new style intake gaskets stop the coolant problems, and the updated spider pretty well takes care of the injector problems. MOST problems with these engines are people not doing the updates, and topping the coolant off and dealing with poor starting.
As to the wires, if they're numbered, they're the factory origanal wires as even the OEM replacements I've done weren't numbered. 100K miles is ALOT of miles, and 20 years on ANY rubber product is asking for trouble. Don't waste your money on CHEAP ignition products. Caps and rotors in these engines have ALWAYS been troublesome. The blue caps are the best IMO, I believe ACCEL sells them, otherwise you can order the marine replacement caps. Do not put another factory plastic type distributor back in it unless you feel like dealing with problems again in the near future. Look on Ebay and you can find all kinds of aluminum replacements for them.
