Will L.
Cleaning the weep hole does actually help a problem, it just allows you to verify if it is actually leaking with in a couple days instead of a week. The ported thing is out of my league.
Low pressure return filters should be used on the steering box only as any restriction in the hydroboost return line will keep the brakes on or on longer.
Say if filter plugs and there is glue spilled on bypass from sloppy manufacturing... Documented condition on some filters made for this purpose.
