Where to start. Truck has about 160k miles on the original stock thin block engine. Ran fine before I tore the truck apart to do upgrades.
Prior to that my TDC offset was showing -2.46, if I moved it back towards the middle I could get it to show like -0.70 but it ran way worse. My actual timing went from 12.0 all the way at passenger side up to 14 as I brought it back to the drivers side a little, and then when I got to the middle of adjustment all the way back to 0.0-1.0 and if I get it to the 3.5 area it runs like shit. My actual timing will not follow the desired timing at all, the time set function doesn't do a damn thing because it isn't even trying to follow the desired timing. I took the stepper motor off hit the ON time set button and it did extend out so it does work but it isn't doing shit when controlled by the PCM.
At this point so much shit has been changed, so much of it is new, I don't even know where to start. And this PCM / Diag tool is one of the shittiest I've ever worked with, the original tech 2 tool was so bad you had to jamb cardboard into the cartridge slots to even make a connection with the candi module, atleast with the laptop tech2win I don't have that problem. Ready to throw this thing off a cliff and burn it as that would be the financially responsible thing to do at this point.
- Wiring stock all in good condition all connectors in great shape no corrosion pins making good contact
- Stock PCM no tune or anything
- Original timing chain
- IP replaced before I got it 10 years ago, truck sat for 8 years while I slowly did a frame off build in my garage literally every single thing is brand new including the bolts minus the engine and body
- Just put a new IP on it (quality source) not sure if I could have moved the IP gear enough during install to put it off a tooth but I guess that is possible
- 2x new PMD's
- Feed the beast lift pump kit with manual switch
- All new lines
- New fuel filter housing and filter
- New tank switch valve
- New tanks
- New pickup tubes and fuel level sensors new fuel gauge
- New bosch injectors
- New return lines
- New turbo
- New glow plugs
- New CKP sensor
