- Staff
- #121
I used a hole saw and drilled into the bottom of the radiator support for the IC lower mounting studs and used the stock DMAX rubber grommets in there. Like I said, it takes ALOT of work to get it gutted down to where you can get the IC to sit far enough into the support to do this. As for the washer bottle, I have a 95 which uses a bottle mounted up on the drivers side fender behind the battery. In 96 GM went to the bottle mounted down low by the radiator support.
